Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Faucet won't stay on (video)
Old 04-09-2012, 04:10 AM   #1
xfactor
Default Faucet won't stay on (video)
I took this video of my faucet. Hopefully it's helpful.
When I turn on the cold water the faucet won't stay on right away. I have to let it run for a while, I guess to let it build up pressure. This started happening a couple months ago.
It doesn't happen with the hot water, only the cold.
I checked that the valve is fully on.
Any idea how I can fix this?
xfactor is offline
Zanne Likes This
Old 04-09-2012, 04:54 AM   #2
Likes Given: 218
It looks like a Moen faucet. Replace the cartridge. If you call Moen's 800# they will send you a new one free of charge.
johnjh2o is online now
Zanne Likes This
Old 04-09-2012, 09:03 PM   #3
mccmech
^^^^^^^ Exactly what he said!
mccmech is offline
Old 04-24-2012, 04:11 AM   #4
Brent
Brent's Avatar
Your handle won't stay up because the internal copper part of the spindle inside the cartridge is to loose. Turn off the supply. Remove the handle, and black or grey bonnets surrounding the cartridge. Remove the clip. Pull out cartridge. Push copper spindle out of the clear cartridge housing. Slightly bend the copper. Reinstall inside clear housing and reinsert the cartridge and install all pieces. Be sure to check for crossed water. This is a common problem with Moen faucets. Good luck
Brent is offline
Zanne Likes This
Old 04-24-2012, 02:55 PM   #5
Mr_David
Liked 9 Times on 8 Posts
Nice!
That's what I do. I usually see this on tub/shower valves.
When turned on the water flow actually pulls the cartrigde back in.
Slightly bend is the key word This will add a little tension on the inside wall of cartridge
Mr_David is offline
Zanne Likes This
Old 04-25-2012, 03:55 PM   #6
DFBonnett
Liked 2 Times on 2 Posts
I had the same problem with one faucet. I got cartridge rebuild kits (I have 4 Moens in the house using the same cart type) from Home Depot Supply and used just the appropriate O rings to replace the worn ones on the spindle. Might be another avenue if bending doesn't achieve the desired result.
https://hdsupplysolutions.com/shop/product-moen_brass_ctg_rebuild_kit_pkg_of_5-498815?rr_cid=498815
DFBonnett is offline
Zanne Likes This
Old 02-23-2014, 12:44 AM   #7
heidimit
Thank you to Brent about slightly bending the copper inside the Moen replacement cartridge. My faucet works at last! The handle stays up and no more leaking. Phew. Other people said wipe the silicon off, but that didn't fix it. Bending the copper did.
heidimit is offline
Old 02-23-2014, 06:47 PM   #8
Matt30
Liked 21 Times on 17 Posts
Ive had this issue with Moens and ive narrowed it down to too much grease on the cartridge. The weight of the handle pushes it down. Ive found wiping the factory lubrication off and just adding my own solves it.
Ive never thought of having to bend the copper a bit. So hey....i learned something today. Sweet.
Matt30 is offline
Zanne Likes This
FVIR Water Heater Pilot wont stay lit after cleaning filter arcsum68 Water Heaters and Softeners 33 11-29-2013 02:35 PM
Pilot light will not stay lit. jeff Water Heaters and Softeners 30 07-13-2013 04:15 AM
Italian water heater not working - pilot won't stay lit bushmlev Water Heaters and Softeners 3 06-01-2011 03:59 PM
Plumbing Video Submission Kially General Discussion 1 07-05-2010 03:06 AM
question about video testing bamaflyfish General Plumbing Help 4 02-22-2010 01:04 PM
