Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Epoxy putty on natural gas pipe?
Old 08-19-2013, 11:16 PM   #1
Steven
Default Epoxy putty on natural gas pipe?
Can epoxy putty or J-B Weld be used to seal a very small leak at a threaded joint in 3/4 inch natural gas pipe? This fitting is in an exposed basement ceiling and the leak is so small it was hard to find, but finally did so using soap solution. It would be difficult to rework the folowing piping to tighten the pipe at the fitting. I called J-B Weld and they said their product could be used in this application, but I would like other confirmation.
Steven is offline
Old 08-19-2013, 11:21 PM   #2
Liked 384 Times on 324 Posts
Likes Given: 550
I would never, ever, condone such a practice on gas pipe.
If it is impossible to disassemble the piping without doing major damage, cutting in a union might be a viable option.
phishfood is online now
johnjh2o Likes This
Old 08-19-2013, 11:37 PM   #3
Steven
Thanks. I was thinking that might be the case. I thought I had read that unions should only be used in the short length between a shut off valve and an appliance. I know you are not to use them in inaccessable places. In my case it would be accessable. Does that sound OK?
Steven is offline
Old 08-20-2013, 12:08 AM   #4
Likes Given: 550
Last time I looked it up in my code, International Plumbing Code, it was legal in an accessible area. Your local code may differ, that is why I said it MIGHT be a viable option.
Old 08-20-2013, 02:58 PM   #5
Steven
Thanks. I will check it out here.
Steven is offline
Old 08-21-2013, 04:18 AM   #6
camaroderrick73
camaroderrick73's Avatar
Liked 30 Times on 29 Posts
You should never repair any gas line with epoxy. Never. UPC is against it not to mention the state of Cali.
UPC approved repair is a left-right coupling or compression fitting.
camaroderrick73 is offline
Natural Laws havasu General Discussion 3 12-17-2012 09:40 AM
Plumbers Putty on plastic index1489 General Plumbing Help 1 03-22-2012 01:26 PM
Natural gas quick release issue Starcraft27 General Plumbing Help 8 01-07-2012 03:34 PM
Plumbers Putty Or Wax Ring? specgrade Toilets and Sinks 14 05-31-2010 07:47 PM
Switching From Natural Gas To Electric Water Heater...What To Do With Gas Pipe/Valve? Abraham General Plumbing Help 3 05-14-2010 02:31 PM
