Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Drilled Hole in Cast Iron Plumbing Stack?
Old 11-22-2013, 03:27 PM   #1
vins0010
Default Drilled Hole in Cast Iron Plumbing Stack?
As background, I have a 1926 Bungalow that has a cast iron main line and cast iron stack. I had a drain cleaner out a few weeks ago to clean the main line both underneath the house and to the street. One of the clean outs (interior) is at the base of the stack in the basement. When he opened it up, he pointed out an unusual hole that looked like it had been drilled through the stack at the base (I've included pictures here). I don't have a trained eye, but, to me, it looks intentional. Is this at all normal? Should I repair it? I was thinking I don't want holes in my plumbing and that I could maybe get some sort of epoxy to cover it...but I've never done this kind of repair before, so I don't know if there is a better way or the procedure for this. I wouldn't be keen on replacing the whole thing. Any expertise or suggestions appreciated.
vins0010 is offline
Old 11-26-2013, 11:03 PM   #2
vins0010
Anyone give me any help here?
vins0010 is offline
Old 11-26-2013, 11:49 PM   #3
Liked 391 Times on 328 Posts
Likes Given: 556
Some two part epoxy would do a half way job of sealing the hole, but eventually the rust that you can see on the inside of the pipe will flake the epoxy off. Clean the area off really well, try to get back to bare metal.
phishfood is online now
Odd cast iron fitting phishfood Plumbing Products 3 11-19-2012 02:38 PM
Changing a copper connecter to a cast iron stack nhilo32 General Plumbing Help 25 06-04-2012 12:53 PM
cast iron main stack as well as drain ronthadon171 General Plumbing Help 1 05-09-2012 02:11 PM
Need help with cast iron please coppens77 Drain and Sewer Cleaning 3 12-13-2011 12:14 PM
Cast out the cast iron? Bodrey General Plumbing Help 4 01-14-2011 02:36 PM
