Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Drain Cap in Basement floor leaks when it rains
Old 07-20-2010, 06:50 PM   #1
Default Drain Cap in Basement floor leaks when it rains
In my basement there is a cap in the floor that is sealed with a wing nut. When it rains, it leaks and partially floods my basement. I have a couple questions. What is the purpose of the cap? Why does it flood? Is this cap something I can replace myself? Will replacing it solve my flooding problem? If it won't solve the problem, what can I do to stop the flooding? Sorry for the barrage of questions, but this keeps happening and I am now fully committed to fixing it. I greatly appreciate any help you could give me.
Javs is offline
Old 07-21-2010, 12:39 AM   #2
Liked 106 Times on 91 Posts
Likes Given: 239
This is just a guess, but my thought is that the wing nut and cap seal a roof drain system cleanout. Do you you have a flat roof on you house that is drained by roof drains?
Otherwise, my second guess is that you have a septic system that is being flooded out by the rains, and the excess water is backing up through this sewer cleanout in your basement.
phishfood is online now
Old 07-21-2010, 01:06 AM   #3
Liked 100 Times on 90 Posts
Likes Given: 19
I'm wondering if this is suppose to contain one of those "one way" check valves, which we have spoken about previously, and needs replacing?
Old 07-21-2010, 10:44 AM   #4
Expert Turd Herder
Reedwalker's Avatar
Its a storm drain and its full of roots.
The wing nut is what we call around here an expansion plug. If I cut out a threaded cap and the threads get trashed in the process, this cap has a rubber gasket that expands when you tighten the wing nut.
Call a plumber!
Reedwalker is offline
Old 07-21-2010, 12:21 PM   #5
Sounds like a Plumbers test plug to me. If you unscrew the wing nut, you can remove the plug. I would do that, when it is not raining, and see if the rubber seal on the plug is decayed or broken. You can buy new one.
majakdragon is offline
drain cap, basement
Basement Floor drain filled with dirt Cambelious Drain and Sewer Cleaning 2 06-12-2012 03:07 PM
Adding a toilet to the basement. Existing drain comes through floor. TSGR General Plumbing Help 3 05-21-2012 04:01 AM
What do I do about a floor drain in my basement before adding carpet? angoved General Plumbing Help 1 11-28-2011 03:00 PM
Basement Floor Drain Pump Up To Sewer?? toddbrew General Plumbing Help 1 04-29-2011 10:13 PM
Basement Floor Drain is slow GJinVA General Plumbing Help 3 12-31-2010 08:38 PM
