Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Double basin sink water backup problem
Old 12-24-2013, 08:31 PM   #1
iamyourdemize
Default Double basin sink water backup problem
Hello! I just installed a new garbage disposal (new install, not a replacement) and now water backs up into either side when draining a basin. Normal operation and normal flow of water from the faucet does not cause it to backup. I am assuming it has to do with how a set up my piping. Any thoughts on how I can resolve this?
All piping up to and including the wye adapter is new. The tube coming from the nipple was clear when I put everything together so I do not think it is a clog.
I attached two pictures showing what it looks like. This is/was my first time doing anything like this some the more details the better. Thanks in advance for any help!
iamyourdemize is offline
Old 12-27-2013, 03:16 AM   #2
kreemoweet
Your piping is fine. You do have a clog. Or underesized drain piping in the wall. Probably both.
kreemoweet is offline
Double kitchen sink clogged Soclogged Drain and Sewer Cleaning 1 11-10-2013 11:45 AM
After plunging sink basin drain, supply water is brown hbrizzims General Plumbing Help 1 06-14-2012 10:12 PM
Replace Offset Double Basin Kitchen Sink bkeye General Plumbing Help 2 01-17-2012 03:56 PM
Kitchen sink drains extremely slowly and backs up (double sink) TimeForAction General Plumbing Help 6 10-22-2010 07:46 AM
