Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Does my washer drain even have a p-trap?
Old 04-13-2013, 10:15 PM   #1
eselick
Default Does my washer drain even have a p-trap?
Hi
I leave in Canada and I don't think p-trap's are required in washing machine drains. I'm getting intermittent sewer smells coming out of the drainage pipe and wonder how to check to see if there even is a p-trap. The drain pipe is about the same height of the washer.
Any ideas?
Thanks
eselick is offline
Old 04-13-2013, 10:37 PM   #2
Liked 385 Times on 325 Posts
Likes Given: 556
I am not knowledgeable on Canadian code, but I would be very surprised if there were not a trap required on any attachment to the sewer system.
I know that Florida code does not allow a laundry to drain onto the ground, it must drain to the sewer/septic, but it is done sometimes.
You could tie a weight firmly to a string and lower it down the pipe until it reaches bottom. If it comes back out wet, you probably have a trap on it.
Old 04-13-2013, 11:12 PM   #3
stevemachine
Liked 89 Times on 78 Posts
Likes Given: 91
I can vouch for Canadian code and I know for 100% fact you need a trap on any directly connected drain to a sewer system.
Old 04-13-2013, 11:57 PM   #4
eselick
Thanks for the ideas and clarification.
eselick is offline
Old 04-13-2013, 11:59 PM   #5
eselick
Now I'm wondering if it does have a trap, why am I getting the sewer smell out of the pipe?
eselick is offline
Old 04-14-2013, 02:19 AM   #6
stevemachine
Likes Given: 91
Sometimes sludge builds up in the traps. If its not accessible you could use an enzyme. That'll usually help eat away at some of the sludge. I know that I've saw plenty of p traps underground up here for laundry drains. I don't think it's allowed anymore but there are some still in service.
eselick Likes This
Convert toilet drain to 2" washer drain hydrostream Toilets and Sinks 2 11-10-2012 10:31 PM
Adding a washer drain to main drain stack.... phantomvs General Plumbing Help 10 07-22-2012 12:18 AM
Washer and Sink drain dsell General Plumbing Help 6 04-01-2012 01:58 PM
Please help, Washer drain problem! MStewart Septic Tanks 2 01-07-2012 08:42 PM
How to add Utility Sink and Washer Drain to existing drain stack obriendigital General Plumbing Help 1 03-27-2011 02:15 AM
