Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Is a check valve inappropriate on a Washer Drain?
Old 07-17-2012, 10:45 PM   #1
dzimney
Grease Monkey
Default Is a check valve inappropriate on a Washer Drain?
I have a slow clog somewhere between my main line and a utility sink in my basement. Until today, the utility sink served as a drain for my washing machine. After being told that I should be draining the washer into an open pipe rather than the sink I re-plumbed the whole deal. My end product is shown in the attached file (diagram excludes P traps). Also of importance, there is a clog/slow drain happening somewhere below the utility sink.
As you can see from the diagram, I put a couple of check valves in the works. My reasoning was that I've had the utility sink overflow from the tub being drained and am assuming the pipe for the washer drain would do the same. I'm also assuming if the tub is backing up, thus closing the check valve(s), and the washer is simultaneously trying to drain, the washer drain would back up.
Now I know that the easiest solution here is to just fix the clog, but I'm trying to avoid water on my floor as much as I can. I would prefer not to find out that the clog has returned by finding standing water in my basement.
Does anyone know if this set up would go against any codes (I realize codes vary from region to region)? Can anyone spot any other possible pitfalls? Or is this, dare I say, a good idea?
Thanks All!
dzimney is offline
Old 07-17-2012, 11:21 PM   #2
It is against code. Check valves are not allowed and each fixture must be vented and trapped. Depending on the area you live you may be able to use AAV vents. I would suggest you hire a plumber to snake the line.
Failing Check valve or foot valve on irrigation well? timfitz Pumps and Wells 3 07-13-2012 12:04 PM
check valve for sewer pumps Mec Drain and Sewer Cleaning 3 03-30-2012 02:29 AM
Is this a check valve? bainboy76 General Plumbing Help 5 01-01-2012 10:51 PM
Swing or spring check valve? sundug General Plumbing Help 3 05-15-2011 03:59 PM
Check out this storm drain run. Chris Project Display 10 04-06-2010 12:24 PM
