Ok ... thanks for all your help.
Job took less than 2 hours.
I used reciprocating saw with carbide diamond blade.
Saw cut through 2" cast iron pipe like butter.
I pushed aside the old pipe and connected the first PVC with fernco.
Connected remaining PVC and finally last fernco.
I used level to check slope (was barely going down hill ... should be good ... I think).
Finally I installed a support hanger strap.
I used a 500w $10 utility lamp from Lowes. It turns your crawl space into daylight.
I also used a heavy gauge extension cord with 3 way grounded splitter on the end so I could attach the saw and lamp at same time.
I had to cut a hole in one of the crawl space vents to get the pipes under the house.
All in all ... it was easy and it saved me $1600.
Thanks again.
