Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Can I reverse a P trap?
Old 03-28-2011, 12:17 AM   #1
Toxarch
Default Can I reverse a P trap?
Can I reverse a P trap? Instead of installing the way they are all normally installed, can I turn it around so it drops down farther?
This is a replacement bathroom sink with a deeper sink than before. There is no more room to move the drain tap piece up. That piece is as high as it can possibly go and I need it for the A/C condensation drain. I can't cut the drain coming out of the wall to turn it down because it's already cut close to the wall. I can't put the A/C drain after the P trap. So the below was the best solution I could come up with. Is it allowed?
Toxarch is offline
Old 03-28-2011, 12:19 AM   #2
Toxarch
If I can't do it with compression fittings, I guess the other option would be going to glued PVC after the slip joint near the wall.
Toxarch is offline
Old 03-28-2011, 01:17 AM   #3
Liked 385 Times on 325 Posts
Likes Given: 551
I have tried something similar in the past. The problem I have run into is that the fitting on top of the left of the trap in your picture is very prone to leaks.
Reverse osmosis problem solving advice chaseme5 General Plumbing Help 2 03-17-2012 04:38 PM
Reverse osmosis water waste markdecker Pumps and Wells 5 07-28-2011 02:15 PM
Reverse Osmosis Question therohz General Plumbing Help 6 12-28-2010 02:21 AM
Chrome Trap arm to ABS Trap? ChuckG General Plumbing Help 5 08-04-2010 10:03 PM
No space for saddle valve for reverse osmosis system. mn3 General Plumbing Help 3 06-22-2010 11:01 PM
