Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Bringing new supply line up through existing slab
Old 02-13-2012, 06:00 PM   #1
Default Bringing new supply line up through existing slab
I am replacing my old leaking Kitec plumbing that is in my slab by running new pex in the attic with drop lines in the walls to the fixtures. How do I get the new supply line into the garage to connect to a manifold? Can I drill straight down through the slab near the outside wall and then dig under the foundation to connect to the supply line? Any help greatly appreciated.
cbbjch is offline
Old 02-13-2012, 11:03 PM   #2
Liked 109 Times on 94 Posts
Likes Given: 240
That should work. I haven't worked with a lot of PEX, so I don't know if it needs to be protected from the concrete or not.
Old 02-13-2012, 11:33 PM   #3
Plumbero007's Avatar
You can drill from inside of the garage at angle, so your drill bit comes on outside bellow ground level, dig hole outside to fond end of your bit. Keep in mind that depends on your location section of the pipe on outside should be deep enough to prevent freezing. PEX will do fine in concrete, make sure to avoid tight turns to prevent kinking the pipe.
Stan
remodel-my-bath.com
Serving ATLANTA and North West GA since 1992
http://remodel-my-bath.com
Plumbero007 is offline
Old 02-13-2012, 11:53 PM   #4
Liked 123 Times on 111 Posts
Likes Given: 70
You should sleeve the PEX were it comes in contact with the concrete. Foam pipe covering works great.
Supply line/faucet line size jm38212 Toilets and Sinks 1 06-24-2012 12:03 AM
Slope of 4” PVC sewer line under slab randym General Plumbing Help 5 01-25-2012 12:05 AM
Instant water heater - existing hot water line in - unit's hot line out to faucet Chuckiechan Water Heaters and Softeners 14 01-23-2012 05:40 PM
Toilet supply line malkee General Plumbing Help 2 06-25-2011 03:22 AM
New Water supply Line markus General Plumbing Help 2 08-28-2010 03:40 AM
