Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Anyone know what this is????
Old 11-07-2013, 10:02 PM   #1
Robwaxman
Default Anyone know what this is????
Has anyone ever seen this before??? It's like a wet black sediment that looks like it came up our shower drain. Help!!
Robwaxman is offline
Old 11-07-2013, 11:55 PM   #2
Liked 384 Times on 324 Posts
Likes Given: 549
Looks almost like a really cool painting of some defoliated trees.
Sorry. Your drain has backed up, and sediment, gunk, and yuckies have invaded your shower as a result. The main drain line will probably need to be snaked.
Zanne Likes This
Old 11-08-2013, 01:32 AM   #3
LockePlumbing
Liked 2 Times on 1 Posts
Time to call a plumber!
LockePlumbing is offline
Old 11-08-2013, 02:59 AM   #4
Mr_David
Liked 9 Times on 8 Posts
usually that type of back up may have occurred while someone was cleaning a drain. Possibly a neighbor, that is if you have common drains with another unit.Cabling a drain stirs up the sludge and sediments.
Mr_David is offline
Old 11-08-2013, 10:49 AM   #5
LockePlumbing
Well this actually happened at my house a month ago and there were roots in the line.
Old 11-08-2013, 01:49 PM   #6
Robwaxman
You guys think I can try
Some main line cleaner? Or is that useless?
Old 11-08-2013, 02:43 PM   #7
LockePlumbing
You can try it but if there is roots it won't help. Best bet is to get someone to run a snake through the main. And not waste any money on drain cleaners.
Old 11-08-2013, 03:37 PM   #8
speedbump
Liked 47 Times on 46 Posts
Likes Given: 13
Do you know if that came up the drain or from the faucet in the tub? The reason I ask is it looks a lot like sulfur off pipes from a well when air gets into the pipes or someone was working on the system.
speedbump is offline
Old 11-08-2013, 04:08 PM   #9
Robwaxman
It's def coming up through the drain. I cleaned it
Out last night and a little came back this morning. I just notched that down the street they were doing some construction to pipes. I wonder if that has anything to do with it.
By the way, the water drains pretty good down that drain.
Old 11-08-2013, 09:41 PM   #10
LockePlumbing
It doesn't matter if it drains good down that drain. It came up through our toilet and tub when we ran the washer and its down stairs everything else is upstairs.
