Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Adding a washer drain to main drain stack....
Old 07-19-2012, 11:52 AM   #1
phantomvs
Likes Given: 10
Default Adding a washer drain to main drain stack....
Hi Guys....
The wife and i decided we would like to move our washer downstairs in the basement. We would like to move it to the left of the main drain stack.
The problem i am having is i am not to sure how to connect the drain & vent. I wanted to tap into existing cleanout but its a 3.5'' ABS and i can't seem to find anything that will fit.
Of course i would of readded a cleanout if it would of worked...so thats out of the question.
Then i thought of cutting the main stack but the height i would have to cut is over 18'' from the floor, cause there is the cleanout and a vent / drain that goes in the garage for a sink.
So cutting all above that to add a washer would be over 18'' from the floor and i am afraid it would be to high for the washer to drain properly ??
I was thinking of maybe trying to remove existing y connector and add a double y connnector ?
Any ideas.....how i can add a washer drain line ??? How would you guys do it ?
I would hate to dig up the floor as i don't want to spend big bucks.
I added a pics to give you guys a better idea of what i am up against.
Thanks in advance !
phantomvs is offline
Old 07-19-2012, 12:15 PM   #2
Likes Given: 218
18" off the floor is not to high. Just cut another Y in above the existing one and connect your trap and vent. The drain for the washer should be 2" but the vent can be 1-1/2". Make the stand pipe from the trap 36" off the floor.
Old 07-21-2012, 12:04 AM   #3
phantomvs
Likes Given: 10
Thanks for the advice John.
Now should i cut in a wYe or a sanitary tee ?
Also since the main vertical 3'' ABS pipe won't give to much i can only glue 1 side so should i use a Fernco flexible coupling on the other side ?
Thanks again !!
Old 07-21-2012, 12:52 AM   #4
Likes Given: 218
A Y would be a better choice. As long as you have a vent between the Y and the trap. Also a banded coupling would be better then a rubber fernco.
http://www.fernco.com/plumbing/shielded-couplings/proflex-couplings
Old 07-21-2012, 11:54 AM   #5
phantomvs
Likes Given: 10
Ok so ...update
I have just realized i have a wet vent.
The new location of the washer drain would be 14 ft away from the main wet vent soil stack.
How should i vent the new washer drain pipe ?
Thanks !
Old 07-21-2012, 12:00 PM   #6
Likes Given: 218
Check with your building dept. see if they allow studor vents.
http://www.studor.com/mini-vent.htm
Old 07-21-2012, 12:07 PM   #7
phantomvs
Likes Given: 10
So John should i just put in a tee in between the trap and Y and run a 1 1/2'' abs to basement ceiling and install a Studor ?
Running it up to roof is next to impossible.
What if i just run a abs tube between trap and Y and reconnect to top of main stack in the basement would that work ..or is it just retapping a wet vent ?
Old 07-21-2012, 12:20 PM   #8
Likes Given: 218
You got it just install the tee between the Y and the trap. But no more then 36" from the trap. It's not necessary to run it to the ceiling, 6" above the washer would be great. They also must be accessible.
Old 07-21-2012, 06:35 PM   #9
phantomvs
Likes Given: 10
Thanks again John you were very helpful .
I will run it like this....
Old 07-21-2012, 06:56 PM   #10
Likes Given: 218
Looks great. Your hired bring your lunch. Glad to be of some help.
Adding three sink to washer drain vaportx Plumbing Building Code 13 01-19-2013 12:00 AM
cast iron main stack as well as drain ronthadon171 General Plumbing Help 1 05-09-2012 02:11 PM
What do I do about a floor drain in my basement before adding carpet? angoved General Plumbing Help 1 11-28-2011 03:00 PM
How to add Utility Sink and Washer Drain to existing drain stack obriendigital General Plumbing Help 1 03-27-2011 02:15 AM
adding basement sink near the dwv stack ew1439 General Plumbing Help 6 11-18-2010 11:52 PM
