#1 | ||
#2 |
Rolled copper with drop-forged (important that they are drop-forged, this means they are suitable for outdoor use) flare fittings is the easiest way.
In most municipalities if you do go below concrete you are required to "sleeve" the pipe. If running along the house use black pipe. You CAN paint it. Rust-Oleum makes many colors. Two or three coats can make it look really nice. Pay special attention to the threads, they can be tough to get thoroughly. Black pipe should not be used underground........ever. |
#3 |
Are you talking like Type K soft copper like we use for water services? I have not heard of using copper for gas. In my business we have run small gas mains that are Poly pipe but I am just not sure for a small thing like this.
I actually went out and looked and my stub out is about 4' from the edge of my concrete so i figure I would run it along the wall of the house then drop it underground the rest of the way. |
#4 |
Exactly what I'm talking about.
1/2" O.D. Rolled K copper should be plenty for your BBQ. The poly stuff is great, but the fittings are super expensive.....like $75+ each. So for a short distance copper is the way to go. CSST (Corrugated Stainless Steel Tubing) is another option but it can also be expensive for the underground rated stuff. Some brands require sleeving even of it is not under concrete. |
#5 |
Copper is usually accepted on the outside of the house, but must switch to hard piping once inside. I have always used black pipe for gas (galvanized can flake off and block orfices). When using it underground, the joints are required to be welded for gas usage.
If you have never made a mistake, you probably haven't done much. |
#6 | |
#7 |
On permanent vacation....
This is what I just installed in my front yard,from my water meter to the house. We were able to bend it (somewhat) but that stuff is very expensive. I would be afraid of kinking the rolled copper, and having to add a union. I myself would encase galvanized pipe, at a fraction of the cost.
#8 |
I would rent a tubing bender to avoid kinks. Not sure how many areas allow sweat fittings in a gas line.
#9 |
I am pretty sure I can get the soft copper to flex to where I want it, I was just wondering. Havasu is talking about Galv pipe sleeved or encased. what do you think of that? I like saving money.
#10 |
Chris...A 50' length of 3/4" rolled copper ran me $196, and because the ends were still real soft, I had to borrow a flare tool to connect the ends. At most big boxes, they have the green plastic (?) coated gas pipe, in 10' or 20' lengths, which is used for underground applications. I'm not too certain what it costs, but it has to be cheaper than that rolled copper.
In my backyard, I was fortunate. When I was adding the pool, I slipped the contractor $50 and he added a gas line for my BBQ, and just tee'ed off his main gas run with the yellow plastic pipe, because he had the cutter and melting seam tool with him. |
