Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Adding drain for water softener
Old 02-09-2014, 08:18 PM   #1
suburbsdiyguy
Default Adding drain for water softener
Hi,
I am installing a water softener in the basement of my home which was built in 2011. There is not any apparent drain location, and the sump pump is across a finished part of the basement so very difficult to access (and I don't really want to ruin the sump pump with salty water anyway). So, I appreciate guidance on the following option.
There is a 3" sewer cleanout sticking up out of the slab in the basement near where I want to put the softener, that is in-line between the basement powder room and the exit of the main stack to the city sewer. I was thinking of adding a 2" standpipe to this, and then have the water softener discharge line sit 1.5" above the standpipe to maintain the air gap. The standpipe would be connected to a p-trap, and then a studor vent before connecting to the 3" cleanout. I would also preserve the function of the cleanout using a san-tee.
Advice on this solution is appreciated!
suburbsdiyguy is offline
Old 02-10-2014, 11:53 PM   #2
Liked 176 Times on 144 Posts
Likes Given: 122
Where is the laundry room in comparison to the softner placement ?
Post some photos of drain piping in the basement.
Old 02-11-2014, 03:02 PM   #3
suburbsdiyguy
Thanks. I could place the water softener 1 floor directly below the laundry room. Attached is a picture of the waste set up behind the powder room as well which could be another option.
I don't have a picture of the cleanout, but it is a 3" PVC sticking up about 12" from the basement slab.
Adding a Drain Pan to an Old Water Heater dsurfer21 General Plumbing Help 10 02-06-2014 02:29 PM
Water Softener/Condenstate Drain Backup Issue f1nALMSfan General Plumbing Help 3 02-03-2014 12:03 AM
Adding sink drain next to washer aads General Plumbing Help 1 01-19-2014 05:38 PM
Washing Machine/Water Softener Drain Issues TkinNJ General Plumbing Help 9 02-09-2013 05:55 PM
Adding a washer drain to main drain stack.... phantomvs General Plumbing Help 10 07-22-2012 12:18 AM
