Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > add subfloor in basement bathroom
Old 05-05-2012, 12:24 PM   #1
Default add subfloor in basement bathroom
I am thinking about adding insulation and subfloor on the basement bathroom floor like other rooms, which will rise the floor level about 2". Do I have to break concrete floor to redo the riser? Can I use the attached flange to avoid modifying riser?
diy001 is offline
Old 05-05-2012, 12:41 PM   #2
Liked 123 Times on 111 Posts
Likes Given: 70
It's hard to tell from the picture, but it looks like you have a 4" cast iron hub in the floor. If it is a hub that flange will not fit. It's made to go into 4" pipe it will be to small to fit into a 4" hub.
Old 05-05-2012, 01:09 PM   #3
Default not a hub
you are right, it is a 4" CI but it is not a hub end. if it is not a hub, i can plugin that flange and make sure it is sealed properly there and it will be fine, am i right?
diy001 is offline
Old 05-05-2012, 02:30 PM   #4
Likes Given: 70
Just be sure you get the inside of the pipe clean. And be sure to screw the flange down to the floor. There is another flange that I prefer. It is the same as the one you have but it has a stainless steel ring.
http://www.plumbingsupply.com/toiletflanges.html
Old 05-05-2012, 03:07 PM   #5
Plumbero007's Avatar
I'm assuming that you got 4" cast iron stub-out currently flush with concrete slab. Measure distance of top of the rubber gasket to bottom of your toilet flange. if you have 2" there you will be fine. After you finish your new floor, bolt your flange TIGHT to finished subfloor then tighten small allen screws on the inside of toilet flange to expand rubber gasket and seal connection.
Good luck
Stan
remodel-my-bath.com
Serving ATLANTA and North West GA since 1992
http://remodel-my-bath.com
Plumbero007 is offline
Basement Bathroom Problem sconova General Plumbing Help 16 04-10-2012 11:55 PM
Please help with new basement bathroom DWV piping layout. chachee General Plumbing Help 1 01-31-2012 07:20 PM
Basement Bathroom Rough-In Help charlie902 General Plumbing Help 9 01-26-2012 12:40 AM
Basement Bathroom Rough-In Picture rhoner General Plumbing Help 8 12-07-2010 11:50 PM
Basement Bathroom kevin General Plumbing Help 8 04-30-2010 03:01 AM
