Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > 1 inch copper union
Old 10-20-2013, 11:05 PM   #1
Mikegp12
Likes Given: 2
Default 1 inch copper union
I am planning on installing unions on the water supply line of my backflow prevention valve so I can remove it during the winter to protect it from harsh winter temps and copper/brass thieves . My concern is that the pipe coming from the basement is only 5 inches long. Is that long enough to install a 1 inch union ? I know that I will have to cut out enough pipe out to make room to sweat on the union fittings. I will attach photo.
Also, Home Depot and Lowes doesn't sell 1 inch unions. My local plumbing supply gets $20 per union. Is that a fair price?
Mikegp12 is offline
Old 10-22-2013, 01:09 AM   #2
Liked 177 Times on 145 Posts
Likes Given: 124
If you are good at soldering you should have plenty of room for 1'' unions.
Mikegp12 Likes This
Old 10-24-2013, 12:15 AM   #3
Liked 385 Times on 325 Posts
Likes Given: 555
What will protect the water main supply against backflow during the winter months when the backflow preventor is removed?
Old 10-24-2013, 03:06 AM   #4
Mikegp12
Likes Given: 2
phishfood,
This device only prevents the irrigation system from backflow. In Missouri we are required to have these in the lawn irrigation systems , not the house water system.
All manufactures recommend removal of the backflow device in cold winter areas. They also say in the manuals to never blow through the backflow, although every sprinkler company I know of blows through the backflow when winterizing the system. I have had to replace the seals, springs, diaphram , and o-rings twice in the last 5 years and suspect this was caused by the compressed air.
Now I am looking for fittings that would screw on the 1 inch union (male end) and connect to the air compressor hose for blow out.
Mikegp12 is offline
Old 10-24-2013, 04:50 AM   #5
Likes Given: 124
Mike, Buy another union just like you have, but get one with threads. With the threaded union you can attach a air compressor NPT coupler or plug. It may be hard to find a 1'' NPT coupler or plug but you can use a reducer bushing. Solder the sweat unions on the piping, then attach the threaded union male/female end to the solder male/female end and blow away. BTW what part of MO ?
johnjh2o Likes This
Old 10-24-2013, 01:12 PM   #6
Likes Given: 555
OK, so the lawn irrigation system will not be in use or connected in the winter.
Never mind me, carry on.
Old 10-24-2013, 01:39 PM   #7
Mikegp12
Likes Given: 2
Thanks IFIXH2O I wll look for those fittings. St.Charles county Mo.
Mikegp12 is offline
gas pipe union jocar General Plumbing Help 2 07-03-2013 10:44 PM
3-1/2 inch fittings rogerlpman Plumbing Products 1 11-19-2012 01:48 PM
Reducing two inch NPS to NPT durk General Plumbing Help 2 03-21-2012 07:47 PM
PVC union peasthope Plumbing Products 2 11-18-2011 01:54 PM
58 inch drop in tub downsouth Showers and Tubs 8 09-30-2011 09:49 PM
