Hi John, thanks for your help. I am going to try to get more details out of you, if that's okay:
Originally Posted by johnjh2o
You need to vent the tub.
Did you see the 2" roof vent that is located very closely to the tub drain, on its way to the main stack? It's within 3 feet of the trap. Is that not close enough?
The tub drain including the trap should be 2" then reduced after the trap.
I will change that! Thanks!
The vent for the toilet can not run horizontal below the flood rim of the fixtures and you can't lay the sanitary tee flat.
Would it suffice if I rotated the sanitary tee 45 or 90 degrees upward (so that it faces the ceiling) and then got another matching elbow so that I could continue the direction outlined in my picture?
Thank you!!
