Go Back   Plumbing Forum > General Plumbing Discussion > Project Display
Old 01-06-2010, 11:09 PM   #1
neither a bird nor plane
bradthebard's Avatar
Default PEX manifold system
In the process of finishing up replumbing an old house with pex.
Here is the central manifold
A shot of the pex runs in the joists.
The tankless water heater that will feed it.
And here is the upstairs hall closet I converted into a laundry closet.
Those are Sharkbite connectors for the hot and cold water, if you can see them. Worked great. No leaks (the threads above them leaked a little though) and installation is literally a question of pushing them on. For small projects they are great, though a bit cost prohibitive on larger ones. I used a sharkbite on a hot water line for three years at the cabin and it never leaked a drop.
bradthebard is offline   Reply With Quote
Old 01-06-2010, 11:23 PM   #2
That is pretty sweet I have never seen PEX used.
Old 01-17-2010, 02:51 PM   #3
Otahyoni's Avatar
So PEX just pushes together? Sounds like the air lines on trucks...
How long is it expected to last versus CPVC or copper?
Old 01-17-2010, 03:41 PM   #4
Always Learning.....
SilverBack4Jack's Avatar
Several different connector styles for pex. The main one used in my area is the crimp style.
SilverBack4Jack is offline   Reply With Quote
Old 01-17-2010, 03:55 PM   #5
Master Plumber
nhmaster3015's Avatar
Don't use metal hangers on pex'
The holes drilled through the joist need to be in the middle 3rd of the joist
When in doubt, hire a licensed professional
nhmaster3015 is offline   Reply With Quote
Old 04-06-2010, 01:15 PM   #6
Looks good
Darren Bosman
-Master Plumber-
www.plumbingthecape.co.za
PEX, manifold, tankless water heater
