Water heater issue
yeah this is gonna sound easy or even cut and dry ,but its been nothing but a headache.
I have a Nat. Gas bradford white waterheater model m2tw50t6fbn that keeps blowing off the relief valve. The house is equipped with a new pressure reducing valve set at 65 psi I have replaced the relief valve and also the therm ex tank ( the previous one was bad) I added pressure to the new tank so that it equals the incoming house water pressure. The heater releases about 2 gallons of water every other day or so. I am assuming the relief valve is going off on temp since the press is only 65 psi at the heater,but the customer has not noticed any difference in temp the water temp is about 130degrees. any help appreciated thanks Tom
