High rise domestic water problem.
I have a 10 story high rise that i am have problems with. I am having cold water feeding into my hot water, causing showers and bathrooms to only have warm water.
I have found my delta p across hot and cold to vary from 4 psig to 13 psig, with my cold water having the higher pressure.
I believe this is my problem but before i start installing pressure regulators in the cold water feeds to these apts i just want to verify i am right.
My cold water feed into the building goes into the building booster pumps before it feeds the building and i am not sure from there where it goes.
Thanks.
