Go Back   Plumbing Forum - Professional & DIY Plumbing Forum > General Discussion > General Discussion
Old 04-17-2010, 07:14 PM   #1
Default CPVC & PVC Pipes & Fittings
Hey all, Im trying to build a cheap camera stabilizer and really dont know much about pipes & fittings. Before I go to Lowes or Homedepot I want to have what i'm looking for ready. Can you help me figure out.
Picture below is what i'm trying to make. I think I need a 1/2 CPVC tee and a 90 degree elbow and not sure the length of pipe
Thanks in Advance
JaneDoe is offline   Reply With Quote
Old 04-17-2010, 08:07 PM   #2
PlumbPr0
getplumbingsupplies's Avatar
what is it exactly you are wanting to know????
Don't lick your fingers before noon. Get Plumbing Supplies
getplumbingsupplies is offline   Reply With Quote
Old 04-18-2010, 01:33 PM   #3
I can't tell the pipe size, but it looks like 3/4" (maybe 1/2") I see 10 45 degree elbows, 3 tees, and less than 3' of pipe. May also have a reducer where the wingnut is installed. PVC should work fine. To assemble this, you will need to build it in two sections and then apply glue and slide the sections together since no unions are shown.
Old 04-18-2010, 05:04 PM   #4
PlumbPr0
yea..hes right..im almost assuming that its 1/2 inch tho...that's a pretty big wing nut lol ...you should put something else in the picture for perspective....
Old 04-18-2010, 08:36 PM   #5
Thanks alot, also do some tees already come with a hole drilled in them or do i have to get it drilled?
Old 04-18-2010, 10:53 PM   #6
It is hard to be certain to tell from the picture, but if it is CPVC, it appears to be 3/4", if PVC, it appears to be 1/2".
T's do not come with holes drilled in them, you will have to drill the hole.
CPVC, PVC, fittings, pipes
