First of all, you don't buy pumps by horsepower. A two inch well may or may not do 30 gpm. A lot depends on the water level in that well. It has to be less than 25 feet or you can forget 30 gpm. You said your getting 21 gpm. What kind of Flotec pump do you have? A jet or a centrifugal? How are you doing this flow test? Are you testing the flow right out of the pump with no smaller than 1" pipe? Into a 5 gallon bucket maybe?
When you design a sprinkler system, you design it to the well, not the well to it. The system can be changed, the well can't. So before you spend the $100.00 on the drawing, do your pump test first. If that Flotec is a jet pump, 21 gpm may be all it can do. With a different pump, you may easily get the 30 gpm needed.
