Go Back   Plumbing Forum - Professional & DIY Plumbing Forum > Specific Plumbing Discussion > Lawn and Garden Irrigation
Old 07-11-2011, 03:12 PM   #1
Default Well and pump set up
I have a well that i want to use for irrigation. I am going to set it up on an automatic timer to do the yard. I am losing prime when I shut of the pump (needles to say that wont work with a timer.)
I have one line with a valve going to the back yard and one going to the front.
If I shut of the valves first I dont lose prime when I turn the pump off. If the valves are open I do lose prime. What do I need to get? A check valve or something? Needless to say I am not a Plumber
notalotofinfo is offline   Reply With Quote
Old 07-12-2011, 03:30 PM   #2
Your username says it all. Not a lot of info.
I would need to know about your well. Size, depth to water, does it have droppipe or just a check valve at the pump etc. Pictures help a lot too.
Old 07-13-2011, 10:59 AM   #3
LOL 1"1/4 drop pipe down 50 ' with a checkvalve
Old 07-13-2011, 01:08 PM   #4
That's it, that's all you know about it? 1-1/4" drop pipe down 50' in what, with what on the end, check valve where? What kind of pump, how many pipes from pump to well, casing diameter.
If you want help, you have to help us.
Old 07-14-2011, 10:56 AM   #5
Ok relax i will get you what you want.
Old 07-14-2011, 01:43 PM   #6
Are you sure... what I really want is a large box of money.
Old 07-15-2011, 10:45 AM   #7
Your wish granted. Address please.
Old 07-15-2011, 01:26 PM   #8
Bring it to Riverview, Fl. Then call me for further instructions.
Old 07-15-2011, 03:07 PM   #9
SB....Please don't forget the obligatory Plumbing Forum tithe when you receive this box o' money!
Old 07-15-2011, 04:19 PM   #10
Oh, I wouldn't think of it. If the box is big enough, I don't mind sharing at all.
