Go Back   Plumbing Forum > Specific Plumbing Discussion > Lawn and Garden Irrigation
Old 01-13-2010, 03:43 PM   #1
Default Prepping for winter?
I live in south Texas and it just started hitting freezing to where I have to wrap my faucets. Is there anything I should do for my automated watering system? I've had it off since late fall but now that I'm thinking about it couldn't the water in those pipes freeze too?
mikej is offline   Reply With Quote
Old 01-13-2010, 09:51 PM   #2
Conway's Avatar
Good question. I never thought about it. Have you gone back and reviewed the instruction manual?
Conway is offline   Reply With Quote
Old 01-14-2010, 01:03 PM   #3
Sprinkler systems should be drained when turned off for the season.
Old 01-14-2010, 07:59 PM   #4
I tried to find out how to do it but I can't even find the manual online. Any body here know hot to drain one?
Old 01-14-2010, 08:35 PM   #5
DIY cuz I'm 2 cheap!
Many irrigation lines can be drained by going to the lowest point of your irrigation line, and removing the sprinkler. You would then need to break the seal at the valve to allow air into the lines. I've also heard you can use an air compressor by forcing air into the line, but again, the valve would need to be opened fully to bleed out any excess water.
Old 01-15-2010, 06:34 PM   #6
I had this whole thing typed up, step by step and I accidentally hit the back button.
Try this:Winterizing Your Irrigation System
If you need more help, I'd be more than happy to assist.
irrig8 is offline   Reply With Quote
Old 01-21-2010, 04:17 PM   #7
Most folks use an air compressor to blow them out. It's not full proof, but it will get most of the water out in most cases.
Content Relevant URLs by vBSEO 3.3.2
