Old 10-29-2011, 02:01 PM   #1
Default Whole house filters
Hi,
Who here has a whole house water filter?
What kind of filter cartridge are you using in it?
How often do you change the cartridge and does it look like it is working, however you may want to define it?
Last question, did you get a water sample analysis that showed what was in your water before you decided to put in a filter?
Thank you for sharing.
DCPlumber is offline   Reply With Quote
Old 10-30-2011, 10:03 AM   #2
KULTULZ's Avatar
Are you asking regarding municipal or well water?
KULTULZ is offline   Reply With Quote
Old 10-30-2011, 03:23 PM   #3
Either one. Also, if you use a filter for ice cube makers or designated drinking water at the kitchen sink/bar sink, whatever.
Just curious what people are using.
Thanks,
Old 10-30-2011, 08:26 PM   #4
KULTULZ's Avatar
Will get back. Will be installing a system in a few days.
SUPPOSEDLY, this system negates point of use filters. Once installed, I will test the water again to see how well it does. If still a little funny, I will use drinking/cooking and ice maker filters. It is on a well and hopefully it won't need shower filters (chlorine being the worst offender I believe).
If you or anyone else knows something that I don't and/or need to know, please chime in. I have been married forty years and not much upsets me anymore...
Old 10-30-2011, 08:32 PM   #5
KULTULZ's Avatar
...forgot...
If one has heavy sediment (well), should a sediment filter be installed before the pressure tank (to prevent fouling the CSV/tank bladder) or does that pose a problem if the filter plugs and the pump works against it?
I plan to use pressure gauges before and after the filtering system to identify any restriction/pressure loss and of course will have a by-pass circuit.
Old 10-30-2011, 11:47 PM   #6
Otahyoni's Avatar
I would imagine with if you have a filter before the pressure switch that if the filter plugs the pressure would build until it blows out the filter element, or ruptures the housing, or a pipe/connection.
My $.02
~The Amish Wolfman
I am known by many names:
Old 10-31-2011, 01:30 AM   #7
I've never installed a filter before the pressure tank, but I've seen it done twice because of such large amounts of sand coming in the well line. Personally, I don't like the idea.
Old 10-31-2011, 10:43 AM   #8
KULTULZ's Avatar
My $.02
You guys make sense. Unless there was a by-pass feature (exensive-subject to failure), it could cause some serious problems including burning the pump.
I am on a learning curve here...
Old 10-31-2011, 02:59 PM   #9
So called "Whole House Filters" are my pet peeve. These things were designed years ago for one faucet. The flow rate through them was somewhere in the one gallon per minute range. Then some genius decided to call them "Whole House Filters" and make a fortune selling cartridges. These things will not remove anything that can harm you except possibly guardia cysts which I doubt seriously you will find in any well. They can't remove iron, calcium, magnesium (hardness) tannin, manganese, sulphur or anything else that is found in water. Only one thing can be removed by them and that's chlorine. For this you need a carbon filter and you can't run the water though it faster than it's design flow rate or you'll push the chlorine through also. Sediment is almost always mineral particles that break loose after accumulating on your plumbing over the years. If not, you have an improperly developed well.
Have your water tested, then save your money to remove something that may be a problem for you. Such as hardness, iron, sulphur gas etc. All of these things require a "REAL" filter, not one of those toy ones.
Sorry, I feel better now. I have ranted yet once again in my quest to do away with these useless things.
Old 10-31-2011, 10:44 PM   #10
speedbump,
Either we are not talking about the same thing or you are letting your pet peeve get in the way.
The whole house filters we install have WAY more than a 1 gallon per minute flow. we almost alway install them upstream of our iron filters and softeners because they almost completely eliminate fouling of the injectors, screens and valves of equipment. If I were more technically capable, I'd take pictures of the 7 filters that I removed and discarded today while winterizing houses.
Our filters remove visible sediment from the water. You say that only one thing can be removed and thats chlorine? We are not using GAC filters and they are removing a lot of crud.
Also, we don't install them to protect people's health. We install them because people that own $500K homes, don't want their $500 kitchen sink faucets and lav faucets getting fouled with sediment. In small weekend cottages, whole house filters keep ballcocks and faucets screens from fouling.
Our service area is almost strictly private wells. Until you see what the ground water looks, smellls and tastes like, you won't believe what we're dealing with. We install all pumps below the casing and even on new wells, the water is pretty bad.
I am not a weekend handyman. I am a licensed master plumber. Our customers hold us to high standards. We have to do whatever it takes to keep the equipment performing. If we didn't filter the water, we'd be servicing softener and iron filters every month.
I don't know if you have Culligan in your area or have heard of them, but even they install filters upstream of their equipment.
My filter in my house is due for a change (every 3 months). I haven't serviced my softener since I put it in when we built 4 years ago. If I can learn how to post a picture I will.
I could never say across the board that whole house filters are worthless and don't filter anything except for chlorine. Our do a whole lot more.
Sorry to rant, but they do work excellent for us.
