Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > Water heater valve leak help
Old 11-02-2013, 04:29 AM   #1
Joanner
Default Water heater valve leak help
A few weeks ago, I noticed there was water in the bucket that has a hose from what I believe is the pressure valve on the water heater. When the propane company came a few days later to clean the furnace, I told them about it. They replaced the valve. But a few days later, there was again water in the bucket. I went through some papers and found that the water heater was quite old and decided to just replace it. New water heater was installed about a week and a half ago by the propane company. Today I noticed there is a little bit of water again in the bucket.
Since I know nothing about plumbing, what sort of problem am I having? Is this a major water pressure problem that requires more expertise than the furnace techs? I have lived in this house 7 years and never had this happen before.
Thanks for any advice you can give me.
Joanner is offline
Old 11-02-2013, 10:55 AM   #2
klee181438
Can you post a picture of the valve? It sounds like a T&P valve. If so, you may want to check the water pressure
In the home. Could be a bad regulator causing the problem
Atlanta, GA Plumber
Metro Septic and Plumbing
678-873-7934
http://www.metrosepticandplumbing.com
klee181438 is offline
Old 11-02-2013, 11:23 AM   #3
Likes Given: 218
You may need a thermal expansion tank.
Caduceus Likes This
Old 11-02-2013, 03:24 PM   #4
Joanner
I googled the T&P valve and that is the valve that is releasing the water.
I assume that a call to a plumber is the next step? (to check the water pressure and regulator-----is this a big job?)
Thanks so much for the advice!
Joanner is offline
Old 11-03-2013, 08:27 PM   #5
klee181438
Depends on If the regulator is in the ground at the water meter or inside the home in an accessible location. A normal T&P is set to relieve around 150 psi or so. If the regulator is bad, it will have to be replaced. If the T&P is old, it will often times need replacing as we'll. Id replace the regulator first and see if that corrects the problem. If you don't have an expansion tank or valve, you'll need one also. Would prob be best to let a licensed plumber make the repairs.
Atlanta, GA Plumber
678-873-7934
water heater tempering valve KULTULZ General Plumbing Help 4 11-01-2011 03:55 PM
Water Heater Leak Issue yeahyeah Water Heaters and Softeners 6 09-12-2011 02:18 AM
Water heater leak with a twist CaliFred Water Heaters and Softeners 10 07-27-2011 01:24 AM
Water Heater Connections Leak jasonbaur Water Heaters and Softeners 5 11-15-2010 07:44 PM
Leak on Hot Water Valve dec1ble General Plumbing Help 1 06-23-2010 10:43 PM
