Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > Water heater insulation wet inside
Old 02-04-2014, 08:05 PM   #1
genocyber76
Default Water heater insulation wet inside
I recently had a couple of pipes burst in the ceiling over my garage. Whole garage was flooded. When the plumber came out to repair the pipes, he informed me that the insulation inside the water heater was wet and per manufacturer, needs to be replaced. The water heater is the original when the house was built jin 1994. I am unsure of the make and model as it has a wrapping on the outside. I was hoping someone might know about this and could offer a second opinion. Any info on this is much appreciated!
genocyber76 is offline
Old 02-05-2014, 01:34 AM   #2
Liked 384 Times on 324 Posts
Likes Given: 550
Considering that the water heater is 20 years old, wet insulation is not the only reason to replace it.
johnjh2o Likes This
insulation dolfans Water Heaters and Softeners 1 11-27-2012 03:26 AM
Water Heater Code Inside home CA usapra Plumbing Building Code 3 08-30-2012 08:09 PM
Moving an inside water meter Uniquenamehere General Plumbing Help 4 08-16-2011 06:40 PM
Gas water heater insulation Sarby Water Heaters and Softeners 3 07-29-2011 11:56 AM
water pipe insulation diy0900 General Plumbing Help 2 08-31-2010 11:51 PM
