Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > Water heater 18" above floor
Old 04-04-2013, 04:33 PM   #1
TravisTea
TravisTea's Avatar
Default Water heater 18" above floor
HOw long has it been a code requirement to install a garage water heater 18" off the floor? This house is 20 years old.
TravisTea is offline
Old 04-04-2013, 04:57 PM   #2
Liked 416 Times on 347 Posts
Likes Given: 62
I'm not sure, but does the code apply to electric water heaters as well as gas water heaters?
Old 04-04-2013, 05:45 PM   #3
stevemachine
Liked 89 Times on 78 Posts
Likes Given: 91
Pretty sure gas only. It's in my gas code not plumbing so I'm pretty sure it doesn't apply to electric but I may be wrong
Old 04-05-2013, 12:07 PM   #4
Likes Given: 219
Gas only. Not required for electric.
Old 04-05-2013, 08:52 PM   #5
TravisTea
TravisTea's Avatar
Thank you . I do see some electric water heaters in garages on an 18" stand. I guess there is no need for one as you all have stated for an electric water heater.
Will a Gearwrench 1-1/2" 6pt. Socket remove a water heater element? rockriver Water Heaters and Softeners 2 01-01-2013 06:26 AM
Any point in 1" supply if water heater is 3/4"? rgeorgejr General Plumbing Help 2 03-13-2012 07:08 AM
Loss of hot water pressure and pipes "vibrate" Mr_Fantastic Showers and Tubs 3 05-20-2011 10:24 PM
Pex water line - connect to 1/2" or 3/4" source SnoSheriff General Plumbing Help 1 03-21-2011 01:47 PM
hot water heater on concrete floor kathymc7719 Water Heaters and Softeners 1 03-10-2011 02:09 AM
