Old 01-10-2010, 02:06 AM   #1
Default Softener Comparison &/or ratings
I'm having a tough time finding any good, unbiased reviews for water softeners. There's features, etc., between brands that a supplier carries, but not a universal comparison. Not Consumer Reports and at least 30-40 supplier & mfg's websites. Can somebody point me to one?!?!
Thanks!!
kwikwater is offline   Reply With Quote
Old 03-08-2010, 02:30 AM   #2
Master Plumber
nhmaster3015's Avatar
Look at Clack and Fleck valves. The Fleck 5600 valve is an industry standard and has been for many years. Solid and reliable. The Clack WS-1 series is a very solid, dependable, simpel and easy to service electronic demand metered valve. Stay away from big box store brands. Kinetico also makes some very nice equipment but you have to have it installed and serviced by a Kinetico dealer.
When in doubt, hire a licensed professional
nhmaster3015 is offline   Reply With Quote
Old 05-25-2010, 10:33 PM   #3
Clack and Fleck valves are your best bet, they are the shall I say set the industry standard. Both are used in residential and commercial applications. Beware of your lesser quality brands, I can give you a bunch of Kinetico valves that did not hold up. DO not buy from the big box stores either as those are if you want to call them "builder grade" THey will do for a short time in a pinch. Your best choice is to call a treatment / filtration company. have them come out, check your water and give you the corrective recommendations. Do not go to a plumber for water treatment problems, they generally have some knowlage ( more than the helpers in the big box stores) but you can wrap up alot of money in equipment and also fustration if not diagnoised, installed properly.
QualityWaterLLC is offline   Reply With Quote
water softeners, Consumer Reports
