Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > New hot water tank.
Old 02-09-2014, 02:00 PM   #1
waterstruck
Default New hot water tank.
Our brand new hot water tank was on a hand truck and being moved into position and when it was being set down ( still on the hand truck) it tipped down rather quickly with a thud. The tank is just very heavy, 250 lbs, so it kind of just got away from the person when setting it down. There was no other noise and the tank didn't move off the hand cart as it was still securely strapped to it.
So my question is how easy is it for the glass liner or any other internal parts on the inside of a hot water tank to break as the thud made me a little nervous?
The tank is a very expensive, glass lined tank with an internal helical coil.
Thank you.
waterstruck is offline
Old 02-11-2014, 12:15 AM   #2
Liked 178 Times on 146 Posts
Likes Given: 130
The way water heaters are insulated these days you should be fine. Supply Co. have scratch and dent sales all the time.
Water hammer caused by hot water tank DJ_Poop General Plumbing Help 6 10-03-2013 02:57 AM
Water in bottom of heater tank - and - hot water in cold lines SteveRiley Water Heaters and Softeners 14 11-09-2012 12:17 AM
Re: New Hot Water Tank trooper1954 Water Heaters and Softeners 3 06-12-2012 04:42 AM
Add Water Storage tank before water heater marksmallz General Plumbing Help 4 04-30-2011 07:52 PM
gel in water tank curchin Water Heaters and Softeners 1 11-17-2010 02:53 AM
