Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > Need a "vent smoke test" video
Old 06-17-2013, 07:43 AM   #1
Renhoek
Default Need a "vent smoke test" video
Hi,
Does anyone know where I can view a video of a "smoke test" to see if my 2004 State Select Hot Water Heater is drafting fast enough?
I followed State's (now AO Smith) user manuals, and there IS air being drawn into the draft hood and out my garage roof vent. But it seems like it's really slow. But I can't be sure. I have to place the smoke (from a stick of incense) right at the edge of the hood for any smoke to get sucked in. There is no sign of a backdraft, thankfully.
There are no videos available on YouTube, and State/AOS can't provide one to me either. I think their Tech Support people have given up on me.
Any help is appreciated. I'd hate to replace the HWH and then have the same problem (the pilot AND burner go out every 15 minutes) if it's a venting issue.
Thanks,
RH in CA
6/17/13
Renhoek is offline
Old 06-21-2013, 01:44 AM   #2
Likes Given: 219
AO Smith was having a problem with their gas heaters. There is a filter under the heater that can get plugged not allowing enough combustion air to enter the chamber. Do a search for AO Smith gas heater filters.
Old 06-21-2013, 05:29 AM   #3
Liked 177 Times on 145 Posts
Likes Given: 124
Have you had this problem since 2004 (Pilot going out often) if not , Have you had any water heater or flue repairs? Is it very windy when the pilot goes out ? Have you cleaned the filter screen as John stated ? Have a drop out test been proformed ? You could very well have another issue besides the flue.
Old 06-25-2013, 11:03 PM   #4
Renhoek
Default Other problems?
Hi,
I just started renting this house last fall. This is the only problem so far, and three plumbers tried to fix this problem back then. No one made a permanent fix.
There is almost no wind in my area. The problem occurs when the garage door is open or closed. The outdoor temperature and weather don't seem related to the problem. There are no flammable fluids in the garage or near the boiler.
The Cordite fire arrestor has been vacuumed thoroughly on the bottom and on the top (through the combustion chamber, when I replaced the thermocouple/TCO switch months ago).
Any other questions and comments are welcome.
RH in CA
PS: see photos here:
http://www.plumbingforums.com/forum/f12/water-heater-insufficient-4158/index3.html#post44561
Renhoek is offline
Old 06-26-2013, 03:38 AM   #5
chukar
Liked 19 Times on 17 Posts
Using a vacuum is not enough you either need to pull the screen out and manually clean it or you need to use a wire brush on both sides of it.
chukar is offline
Old 06-26-2013, 11:54 AM   #6
Likes Given: 124
Originally Posted by Renhoek View Post
Hi,
RH in CA
RH, You should stay on your landlord to take care of the problem. Gas water heater are very dangerous and should have a qualified professional repair them. I don't think the problem is in the flue, look at the plastic blue and red hot & cold water indicators at the top of the water heater. If the flue wasn't drawing proper those plastic indicators would have melted by now or would have rolled up. I think your problem is elsewhere and should have a professional take care of it. Good Luck....
Old 06-27-2013, 06:24 PM   #7
stevemachine
Liked 89 Times on 78 Posts
Likes Given: 91
I agree definitely get a pro to fix it. I know I have seen tons of TCO switches fail if 3" venting was used on them. The issue keeps repeating unless the flue is fixed. But it's hard to judge online, I think the flue needs to be changed to 4" to meet codesl. Get your landlord to fix this. Like Ifix said gas water heaters aren't something to toy around with.
Old 07-12-2013, 11:33 PM   #8
Renhoek
Default Smoke test video found
For anyone who cares, I finally found a video showing a smoke test (at about 3 minutes in):
Based on this video, my draft & exhaust vent is definitely my problem. The smoke I placed near my draft hood just barely got sucked in. Must be a dead squirrel cooking up in there!
RH
Renhoek is offline
Old 07-12-2013, 11:37 PM   #9
Renhoek
Default 3" vent is correct -- per AOS
Hi,
I specifically asked if a 4" vent is needed for a 50 gallon tank, and the "experts" at AO Smith's Tech Support said that 3" is the correct size venting.
If I can't trust them, who can I trust?
Thanks for your reply,
RH
Renhoek is offline
Old 07-12-2013, 11:42 PM   #10
Renhoek
Default Cordite flame arrestor
From what I've read, the ceramic Cordite flame arrestor is press-fit into the bottom of the chamber, so it can't be removed.
I have vacuumed the top and bottom using a Shop-Vac, and have carefully scrubbed the bottom with a refrigerator-coil brush. I don't want to crack the ceramic by using a wire brush.
I've also pushed a guitar string through many of the holes and it hasn't made a difference, so I think the air is coming through OK.
Thanks for your reply. Keep `em coming.
RH
Renhoek is offline
"The official uniquely randomized designed thread" Chris General Discussion 1275 Today 12:17 PM
Adjustable "Metric" and "SAE" wrenches? havasu Plumbing Tools and Equipment 3 04-12-2011 06:58 PM
venting 4" stainless thru existing 6" B vent superfitter Water Heaters and Softeners 1 03-28-2011 01:50 AM
Outside spigot with plastic "winterizing" piece causing leak thunderbry General Plumbing Help 2 06-19-2010 01:09 PM
Vice President Joe Biden or Jeff Dunhams "Walter" SilverBack4Jack General Discussion 5 01-30-2010 12:53 AM
