Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > Hot Water Leaking ):
Old 10-12-2013, 11:18 PM   #1
joshshay
Default Hot Water Leaking ):
So recently, my hot water heater in the garage has been leaking so I shut off the gas as well as the cold water inlet valve. I took my water heater out and had it recycled. While waiting for the new water heater to be delivered, I noticed that whenever a faucet is cracked opened in the house, water shoot backs out of the hot water outlet valve in the garage, causing a huge leakage. How do I fix this? There isn't a shut off valve for the hot water outlet. Thank you for reading
joshshay is offline
Old 10-13-2013, 12:17 AM   #2
Liked 416 Times on 347 Posts
Likes Given: 62
Sounds to me that when you open a faucet, you are venting the system, allowing the water to purge from the line. This is similar to filling a straw with water, with your finger stopping the air flow. Remove your finger, and the water in the straw will drain out. Once you install the new water heater, this action will stop.
joshshay Likes This
Old 10-13-2013, 12:22 AM   #3
joshshay
Thanks for the reply Havasu, really appreciate the feedback. Thanks again!
joshshay is offline
Old 10-13-2013, 01:45 AM   #4
Liked 385 Times on 325 Posts
Likes Given: 555
A faucet mixes hot and cold water inside of the faucet body. So if there is no pressure on the hot side, the pressure on the cold side pushes the water back through the hot water piping, and out of the open pipe in your garage. If you can post a picture of the open piping in your garage, we should be able to recommend a temporary cap solution for you.
Caduceus Likes This
Shower Leaking hot water, Replaced O Ring, Still Leaking, Need Help bjornbjorn Showers and Tubs 4 10-09-2013 11:36 PM
leaking water regulator? dang General Plumbing Help 3 09-05-2012 02:33 AM
Gas water heater leaking from top??? VBDream126 Water Heaters and Softeners 2 05-08-2012 03:28 AM
drinking water filter leaking gymgrrl General Plumbing Help 2 01-13-2011 01:41 PM
Pur Water Filter Leaking Schwartzman Toilets and Sinks 2 01-06-2010 12:41 AM
