Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > Hot water heat question
Old 06-18-2013, 10:49 PM   #1
corndog
Default Hot water heat question
Hi guys/gals,
I'm a bit of a greenhorn when it comes to these things - I have some basic knowledge of these subjects, but I am a little confused here.
Backstory: I am buying my first house and had an inspector go through it. The report came back clean, save the HWT. The house has been vacant for months, but they never turned the water off in the house. The inspector noted that the water is flowing out of this 'overflow' pipe out of the top, attached to the ball valve. Note it isn't the T&P relief. I am unsure why there would be a drain on what I presume to be the inlet of the HWT. The tank is 3 years old. I have attached some pictures, and hopefully someone can shed some light on this because I am
http://imageshack.us/photo/my-images/855/q9ar.jpg/
http://imageshack.us/photo/my-images/199/bq22.jpg/
http://imageshack.us/photo/my-images/11/jhr9.jpg/
corndog is offline
Old 06-18-2013, 11:09 PM   #2
Liked 384 Times on 324 Posts
Likes Given: 550
Though I have never seen one quite like that, I believe that it is a thermal expansion valve. A thermal expansion valve is meant to relieve the excess pressure that is created when a full (or nearly so) tank of cold water is heated and the water expands. If I am correct, replacing the thermal expansion valve should solve the problem.
phishfood is online now
Old 06-18-2013, 11:23 PM   #3
corndog
Looks like you are right. Found what looks like that valve.
http://www.directindustry.com/prod/conbraco-industries/thermostatic-expansion-valves-9063-686413.html
Water has been pouring through it since ~Jan, so I am guessing the current owners are going to have a monstrous water bill.
I just hope is a faulty valve and not the hwt.
corndog is offline
Old 06-19-2013, 01:50 AM   #4
Likes Given: 550
The water heater itself is not likely to be causing this.
johnjh2o Likes This
Old 06-19-2013, 05:59 AM   #5
corndog
Great. Thanks so much!
corndog is offline
Old 06-19-2013, 12:59 PM   #6
speedbump
Liked 47 Times on 46 Posts
Likes Given: 13
I wonder where they thought that heater was going, having it strapped to the wall like that??? Or is this in the land of Earthquakes?
speedbump is offline
Old 06-19-2013, 02:01 PM   #7
corndog
Correct. West coast BC, pretty seismically active.
corndog is offline
Old 06-19-2013, 10:44 PM   #8
chukar
Liked 19 Times on 17 Posts
Thermal expansion valves were becoming required in water districts like burnaby, I like to use them as a trap primer. If your in BC lower mainland there is a 50/50 chance of even having a water meter. When I lived in coquitlam we didn't have a meter but it was part of the flat rate we payed to the city, for garbage and sewer.
chukar is offline
Old 06-23-2013, 07:00 AM   #9
FML
It's Thermal Expansion Valve Installed Opposite . The drain port suppose to towards the tank . ( so even if the ball valve is off & tank is on ,it still does its job )Saves pipes & tank from thermal expansion (extra pressure ) . These valves are usually adjustable(factory set under 80psi) . But before u think / check something else , Check your Domestic water Pressure .( PRV on main water Stop ). Raj ( Farid Mechanical Ltd .)
FML is offline
johnjh2o Likes This
heat-pump type water heater RustyShackleford Water Heaters and Softeners 6 12-20-2012 10:20 PM
Tankless Hot Water Heater, Noritz N0751M Will Not Heat Water iceundersiege Water Heaters and Softeners 6 04-03-2012 03:21 AM
no return valves on water heat system in 50 unit building Damianbx Plumbing Building Code 4 03-30-2012 02:35 AM
Hot Water Heat and Pump andy867 Water Heaters and Softeners 4 05-11-2011 02:03 PM
Heat pump water heater drain lines sparky472 General Plumbing Help 9 03-22-2011 05:04 PM
