High pressure causing relief valve leak?
After install of new 80 gal elec heater, small intermittent leak from temp pressure valve. Changed valve, still leaks. I checked the pressure and I am running aroun 82 PSI. Does anyone know the remedy? Do I have to go to a pressure reducing valve, or will a neck down section from 0.75 to 0.25 inches suffice?
