Old 05-09-2010, 09:39 PM   #1
Default Do I need to disinfect water softener?
My softener has sat idle for a couple of years. Do I need to disinfect it? If so how might I do that?
bendj is offline   Reply With Quote
Old 05-09-2010, 11:27 PM   #2
I don't think it is necessary unless it is so rancid and moldy that cleaning is a must. In this case, I would wash the container out, and add a solution of bleach and water, in about a 100 to 1 ratio, or one ounce of bleach to a gallon of water. Scrub and rince a few times afterwards.
Old 05-10-2010, 04:39 PM   #3
You could add some bleach to your brine tank just before a backwash. That would draw the bleach into the mineral tank during the brine and rinse cycle. If there are any little buggers living in there, a 1/4 cup of bleach aught to do them in.
Old 05-11-2010, 02:09 AM   #4
Thanks for the info. Couldn't be easier.
water softner, disinfect, flushing water softner
