Plumbing Forum - Professional & DIY Plumbing Forum > Specific Plumbing Discussion > Water Heaters and Softeners > Can I remove this pipe next to water heater?
Old 08-31-2012, 01:12 AM   #1
Default Can I remove this pipe next to water heater?
I want to remove these two metal things, but I'm not sure what they are or if they serve an important purpose.
These things are located in a 10x8 or so water heater closet at the end of our 40-year-old house. The closet is accessed through its own exterior door, not through the house, and it is not temperature-controlled, but it does share a drywall wall with our bedroom. Which is barely insulated, but that's a different thread.
The current water heater is a gas model that was installed a couple years ago.
Neither of these things is connected to the current water heater at all, at least not below ceiling-level, where I can actually see what's going on.
1) Thing A just seems to be a short metal vent-like cylinder that surrounds a hole in the ceiling. When I reach inside it, there is nothing above it on the other side of the ceiling in the attic.
Is this left over from an old water heater? Can I remove this and patch the ceiling, or is there to ensure plenty of fresh air and no buildup of (fumes? gases?)?
2) Thing B is a long metal tube that presumably goes through the ceiling. It's attached to the wall and open on the bottom. Nothing else is attached to it. (The copper tubing to its right runs right past it, but isn't actually attached.)
Same question - is this left over from a previous water heater? Can I remove this and patch the wall and ceiling, or is it serving a useful purpose?
Photo's attached.
Many thanks!
Lucy
lucymiella is offline
Old 08-31-2012, 03:19 AM   #2
Liked 15 Times on 14 Posts
That is your code required combustion air openings for the water heater (one high and one low). They need to stay just as they are. They provide make up air to the water heater. If they were removed, the flue gases could be drawn back down for combustion and spread to the rest of the house.
Beni is offline
Old 08-31-2012, 02:02 PM   #3
Thank you - makes perfect sense. Had a feeling that might be the case.
Now, a related question - this is a 40 y/o house whose maintenance was apparently often deferred.
So I looked up inside the one on the left (A) with a flashlight, and it's not blocked by debris - all looks good for unobstructed air movement.
Obviously I can't check the one on the right without taking something apart.
Should I do that, just to be on the safe side? Or is the fact that we're all still here, breathing and in one piece, enough evidence that the other air opening (B) is unobstructed?
Thanks much!
Old 08-31-2012, 02:07 PM   #4
And would it be a good idea to add a plug-in carbon monoxide detector/alarm in this closet?
Old 08-31-2012, 06:28 PM   #5
Liked 63 Times on 55 Posts
Likes Given: 15
CO detector is a good call. If you don't have enough air and the water heater fires, incomplete combustion can occur and CO is a by product of incomplete combustion. It's not very likely to happen but if it does at least you'll know.
Old 09-01-2012, 01:18 AM   #6
Liked 66 Times on 56 Posts
Likes Given: 53
I would recommend putting the co detector in the main house , putting it close to the water heater can cause false readings. Check the sensor info on the co detector before you buy, Most sensor have a life span between 2 & 5 years, if you find one that have a longer life I still would replace the unit after 5 years, most people aren't aware of this. On most co dectector when you press the test button you are testing the alarm NOT THE SENSOR. I think co detectors should be in every home that has a gas water heater, furnace,boiler they save lives.
Old 09-01-2012, 02:49 AM   #7
Likes Given: 15
Definitely agree after I re read the question. In the house/living area would be best.
Old 09-03-2012, 03:11 AM   #8
Typically CO is a byproduct of any combustion complete or incomplete. As long as the upper combustion is clear everything will be fine. Most counties where I am from only require an upper combustion anyways.
joshuameares is offline
Old 09-03-2012, 10:19 PM   #9
The fact that there are two combustion air openings shown, would tend to point that both are required by code, where the OP is located. Having designed projects from coast to coast, pretty much all the mechanical and plumbing codes used in the US require two combustion air openings for interior spaces with atmospheric gas water heaters or furnaces are located.
Beni Bacon, PE, CIPE
Beni is offline
Old 09-04-2012, 03:03 PM   #10
Depending on what city you reside depends in the actual codes enforced. There is also something called going above and beyond. In my experience, and I mean from actually doing the jobs and getting my hands dirty, I've put upper and lower wherever upper is only required because it only takes an additional 5 minutes and 5 dollars of material.
Water heater connection to boiler domestic hot water coil gillric Water Heaters and Softeners 2 11-11-2011 11:16 AM
Advice needed to remove a pipe oakumboakum General Plumbing Help 1 09-08-2011 04:15 AM
Water heater pipe leaks prematurely thezman General Plumbing Help 9 06-29-2011 04:50 AM
Need to cap off an iron water pipe 3/4 for renos, do I need to thread the pipe? drchalifax General Plumbing Help 1 05-20-2011 09:04 PM
Switching From Natural Gas To Electric Water Heater...What To Do With Gas Pipe/Valve? Abraham General Plumbing Help 3 05-14-2010 02:31 PM
