Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > air coming through faucet from water heater after overnight sit.
Old 11-29-2013, 12:11 PM   #1
kudzu
Default air coming through faucet from water heater after overnight sit.
I get a small amount of air each morning only from the hot water faucets, at least, I never noticed from cold water tap. I have a softener system if that has any involvement. This is noticeable after overnight resting of the system.
thankyou for your information.
kudzu is offline
Old 11-30-2013, 02:38 AM   #2
kudzu
I read that the anode may cause this. I also heard that electrical bleeding through tank into concrete may cause generation of air bubbles. Anyone heard this?
kudzu is offline
Old 11-30-2013, 02:24 PM   #3
kudzu
Default more infomration on hoter air bubbles
I live on a well and each morning I get a small blast of air when hot water faucet is turned on (only in my hot water line) and this has started only in the last week (26 NOV). Some background information. I filled a glass with cold water and let stand overnight. In the morning there were some bubbles along the side of the glass. Middle of Oct, I had repairs done in the backyard which required a bobcat hauling dirt to go over my well line. The construction people told me that the weight of the tracked bobcat carrying dirt was not enough to damage the pipes - I live in State of Maryland. I also drained the hot water heater in the beginning of NOV as water temp seemed lower - since then, the water has been hotter. I did not adjust the thermostat - 116 degrees. My hot water heater sits on several bricks which are in contact with the concrete. I have not tried to shut off the well pump and let system stand for the day - hard to do with everyone home. I have not noticed any drop in pressure after a couple of hours. The air discharge is a single burst and all good for rest of the day - so far. Also have a water softener and added salt 3 days before occurrence.
Thank you for any assistance
kudzu is offline
Old 01-01-2014, 04:46 AM   #4
badgermilker
Liked 3 Times on 3 Posts
Sounds like thermal expansion. How old is the tank?
badgermilker is offline
High Pitched Sound Coming From Hot Water Heater Spike Water Heaters and Softeners 4 02-15-2013 03:53 PM
Water coming out of water heater power vent stevemachine Water Heaters and Softeners 6 12-23-2012 03:36 PM
4 pipes coming from water heater? emo7874 Water Heaters and Softeners 3 01-28-2012 05:13 PM
Instant water heater - existing hot water line in - unit's hot line out to faucet Chuckiechan Water Heaters and Softeners 14 01-23-2012 05:40 PM
Only Air Coming out of Hot Water deceived Water Heaters and Softeners 14 12-20-2010 01:45 AM
