Ah ok well then yeah you may want to consider either another water heater, or a bigger one. Also tankless might be a good option for you depending on what you're willing to spend. Tankless is nice cause its unlimited hot water, however they do require maintenance, and a water softener, if your water has any hardness at all. The tankless are quite efficient too, so they'll pay themselves off in the long run. Call out ideally 3 plumbers and get quotes to do the work, whether you want that extra tank/bigger tank or a tankless water heater
