Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > 17 year old Kenmore still running - replace?
Old 08-30-2013, 06:54 PM   #1
sumdumgai
Default 17 year old Kenmore still running - replace?
Hello. My first post here and hoping to get good advice. I have a Kenmore 50 gal nat gas water heater, with 10 year warranty, that was installed in early 1996. It shows no signs of going bad. Should I go ahead and replace it or let it go until it does shows signs? Thanks.
sumdumgai is offline
Old 08-30-2013, 11:59 PM   #2
Liked 384 Times on 324 Posts
Likes Given: 550
That will depend on some other factors.
Where is it located? If it is in a location that a leakage failure could cause water damage, then I would replace it. If it is in an open carport with positive drainage, then I might not recommend replacement.
How is your water? If your neighbors have a service plumber on speed dial due to water heater failures, or repipes, then I would replace it last week.
Zanne Likes This
Old 08-31-2013, 12:01 PM   #3
Liked 176 Times on 144 Posts
Likes Given: 122
An add-on to what Phishfood has said. The average life for a water heater is 8 to 13 years depending on different factors -- water quality, usuage, etc. Water heaters sometimes shows no signs of failure (signs a home owner might not notice) before failing. Rub your hand down the seam of the water heater , the seam will be in the back of the water heater. You're checking to see if the seam is in tact and not bulging/pulling apart. I will just about bet money your Anode rod is just about completely gone. A new water heater will be more efficient than the one you have now.
Old 09-02-2013, 11:05 PM   #4
sumdumgai
Thanks for the input. The water heater is in the basement, most of which is finished. So, if it leaks a lot or bursts a seam, it would do a lot of damage. Also, the anode has never been replaced. I'm going to replace it this month.
Kenmore display interpretation killermrob83 Water Heaters and Softeners 3 04-27-2013 01:32 PM
85 year old cast iron pipe phishfood Drain and Sewer Cleaning 3 06-29-2012 01:53 AM
Heads up please. 2 year old dies... ddocfletcher Septic Tanks 3 03-13-2012 02:03 PM
Toilet keeps backing up. Over a year now. cav Toilets and Sinks 3 01-05-2012 12:52 PM
Please Help. Need Help With finding a 30 year old Gate Valve russell333 General Plumbing Help 11 10-21-2011 12:17 AM
