Go Back   Plumbing Forum > Specific Plumbing Discussion > Septic Tanks
Old 09-03-2010, 10:01 AM   #1
Default Septic tank question..
we have moved into rented accomodation and the kitchen sink seems to be blocked?
everything else seems to be draining away ok.( in the batroom etc). but my partner says that its because the septic tank needs emptying....surely nothing would drain away if that was the case.
Home Renovation Brisbane
Commercial Water Tanks
rtlplumbing is offline   Reply With Quote
Old 09-04-2010, 04:42 PM   #2
I agree with you. If it was a septic tank problem, nothing would drain properly. Remove the trap under the problem sink and see if it is full of junk.
