Plumbing Forum - Professional & DIY Plumbing Forum > Specific Plumbing Discussion > Septic Tanks > Recommend a high quality line of effluent pumps
Old 11-29-2012, 03:24 AM   #1
Default Recommend a high quality line of effluent pumps
Hello, new member here. I have an effluent pump in a pit on the outlet of my septic tank. I am replacing a Zoeller Model 53 pump that has been in service about 7 years, which I have had several problems with. This is the type that comes with a float attached to the outside.
QUESTION: Can someone recommend a high quality line of pumps that I can expect long problem-free service from? I am willing to pay more for quality here.
What problems have I had? Animal chewed thru pump wiring from inside. String caught in float mechanism. Pump stopped turning on when float rose, replaced switch and problem remained. Now water is inside switch cover. I see rust in several places so I'm ready to replace it.
Some background--a septic man recommended the pump system because our field just did not seem to absorb the water when it was cold and wet outside. I believe there is a lot of clay in the soil.
Thanks for any advice.
BasicPoke (Ron)
BasicPoke is offline
Old 12-02-2012, 08:12 AM   #2
Stay with zoeller sump pumps they Rs cheap and high quality
drainbrain is offline
Old 12-11-2012, 05:08 AM   #3
Thank you drainbrain. I ended up buying a Liberty pump but haven't received it yet.
Old 12-12-2012, 02:12 AM   #4
Liked 58 Times on 52 Posts
Likes Given: 11
Liberty makes a pretty decent sump pump so I would imagine the quality should be par. Let us know how it works out.
stevemachine is online now
Where to buy good quality? Sarah21 Plumbing Products 4 09-30-2012 01:29 AM
I'm looking for a good quality Tub Faucet Gregavi Showers and Tubs 3 09-21-2011 08:37 PM
HP of Booster Pumps elmer Pumps and Wells 1 08-14-2011 03:31 PM
Sump pumps Septik Pumps and Wells 4 07-06-2011 05:28 PM
Recommend a Kitchen Faucet! casualfc General Plumbing Help 7 03-24-2011 04:34 PM
