Originally Posted by Conway
Brad what is typical for some one to flush down? 1,200 seems like a lot of water for daily use.
Typical American household uses anywhere from 300 to 500 gallons per person per day. That is an average and may be a little skewed with residential irrigation in some areas, but none the less, we Yanks tend to use a boatload of water.
That said, those numbers are a few years old and are dropping with the more widespread use of water conserving showerheads, toilets, etc.
On an interesting note, when I was hauling water in for my cabin, we would average about 15 gallons a day for the whole family (you learn to conserve when you haul it in by hand). The drains ended up clogging up because the county stipulated 1/4" per foot max drop and we weren't putting enough water in to flush out the toilet paper and poo! (if you are wondering, we hand filled the toilet tank until the supply side plumbing was installed).
ALso, I believe most tanks are in the 800 to 1000 gallon range for a residence, though it may vary locally.
