Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Septic Tanks > Help with American Drip system
Old 01-14-2014, 12:24 AM   #1
jamielarsonr2r
Septic service/repairman
Default Help with American Drip system
Hey guys-
Need some suggestions on thawing frozen drip zones on a 3 zone American Drip system. With the extreme cold and now a couple warmer days the freeze line in the ground has gotten considerably deeper. I have attached a drawing also if that helps. The lines I'm not even sure if they are frozen. The lines that go out from the hydraulic assembly to the header pipe will not take any water(or salt brine), even under pressure. Presuming those are where the problem begins. Air relief valves at the front of the drain field were full of ice. I need to get this resolved somehow. Spent nearly eight hours on it today with no results. Any help would be awesome. Thanks!
jamielarsonr2r is offline
Old 01-15-2014, 12:04 PM   #2
Liked 176 Times on 144 Posts
Likes Given: 122
Probably start by opening the supply lines just after the pump to see if water pressure is there, if so, reattach lines then open lines close to the zones to check for water pressure. If no pressure supply lines may be frozen. If you have pressure reattach lines then open return line close to zones to check for water return water. If no water your zones may be frozen. With out being on site this would be my process of elimination. Check all check valves that's on that side of the system.
Old 01-15-2014, 02:08 PM   #3
jamielarsonr2r
Hey thanks. I've gone through those steps. I have pressure out from the hydraulic unit to the first set of air relief valves which are under a lid. From there to the header pipe I have no flow and no flow on the return. So my guess at this point, being day 3 of this mess, is that the supply lines to the header pipe and the zones are frozen. Seems that we will be building a warming tent today. Both of the frozen drips I've been working on this week are in yards that the homeowner has aerated heavily.
Old 01-15-2014, 11:28 PM   #4
Likes Given: 122
Ouch... How deep are the supply & return lines ?
Hot Water Heating System Versus Hot Air System. Hudson General Plumbing Help 9 08-02-2013 05:27 PM
Install Looped Mainline for Drip Irrigation 1000' dishheadd General Plumbing Help 11 04-14-2012 02:35 AM
Drip Drip vabear General Plumbing Help 2 02-28-2012 11:52 PM
Drip in bathtub bozonoz General Plumbing Help 2 07-15-2010 09:40 PM
American Standard problem. CPTTango30 General Plumbing Help 1 05-03-2010 05:55 PM
