Plumbing Forum - Professional & DIY Plumbing Forum > Specific Plumbing Discussion > Pumps and Wells > Well pressure not changing, thus ,switch not kicking on
Old 11-03-2012, 10:49 PM   #1
bikeman732
Default Well pressure not changing, thus ,switch not kicking on
Been in this house 2 years. Well is used only for outside spigots, top off pool, and irrigation. Galvanized tank was waterlogged once and I fixed that. pressure switch about 18 months old. turned on irrigation for the first time in months and I have pressure, it is working, but when I went to the tank the guage is staying at 35psi or so and not causing pump to kick on. I opened the tank drain valve so it dropped below 30psi but still no kick on.
Is my pressure switch bad again? is it bad to run it in this condition? Or is this not a problem.
bikeman732 is offline
Old 11-04-2012, 09:26 AM   #2
Liked 162 Times on 137 Posts
Likes Given: 86
Pressure switch or the line feeding it is plugged.
johnjh2o is online now
Old 11-05-2012, 03:00 PM   #3
speedbump
Liked 26 Times on 26 Posts
Likes Given: 11
If you have pressure, then the pump must be running. The gauge can be stuck on 35. That's a normal occurrence for cheap gauges.
If you run out of pressure, then it's like John says, plugged line.
speedbump is offline
Issue w/ well pump, pressure tank or pressure switch??? pmoney1983 Pumps and Wells 2 10-27-2012 01:48 PM
Pump pressure changing. Chris Pumps and Wells 66 05-08-2012 06:29 PM
Pressure Switch or Pump problem? ericivins Pumps and Wells 7 01-17-2012 08:41 PM
Pressure switch bouncing on cut-off lennysfo Plumbing Products 9 07-01-2011 12:18 AM
Adjusting pressure switch with one spring only? omar2726 General Plumbing Help 5 05-23-2011 02:27 PM
