Plumbing Forum - Professional & DIY Plumbing Forum > Specific Plumbing Discussion > Pumps and Wells > Well advice requested
Old 05-08-2012, 03:15 PM   #1
Liked 100 Times on 90 Posts
Likes Given: 19
Default Well advice requested
My cousin has a well at his Lake Arrowhead residence. He has city water and a well so he can take advantage of using his cheaper well water primarily for irrigation, but when turned on, will supply water to his entire house.
Besides the stop float falling to the bottom of his 500 gallon tank (estimated) recently, it seems to be operating without any problems. He did have a well specialist come out who recommended he install a shut off valve to the tank discharge line for ease of maintenance, does anyone see any problems with this set up?
What type of maintenance do you recommend? He does have about 3/4" of silt in the bottom of his storage tank, which we plan on sucking out soon, can any of you advise the best way to remove the silt? Can you experts give me any tips to keep this running in good condition?
Any and all comments would be appreciated!
Old 05-08-2012, 03:44 PM   #2
Liked 118 Times on 108 Posts
Likes Given: 70
One thing I will mention is there should be a back flow device on the city water line. Without one he could contaminate the city water with his well water. I'm sure if the city was aware that he had a cross connection between the two water supplys they would require he install one.
Old 05-08-2012, 03:51 PM   #3
Likes Given: 19
I took a peak at the city water inlet near the street and saw a back flow device was installed already. I even saw a leak down there which needs attention though.
Old 05-09-2012, 02:56 AM   #4
Water well,and septic guy
waterwelldude's Avatar
Liked 2 Times on 2 Posts
From looking at the pictures it would appear that there are two pumps here.
One to fill the storage tank and one to pressure the system.
Am I correct is my thinking? If so, here are my thoughts.
That is a good setup. We have the same thing set up on a larger scale for a sports ranch. The only thing I would say( if theres not one) would be a cut off float in the storage tank. A safety switch as it were. One to stop the booster pump from running if the storage tank ran out of water before the system was pressured up.
Its a good setup and works very well.
Edit Signature
waterwelldude is offline
Old 05-09-2012, 03:06 AM   #5
Likes Given: 19
The system worked great until a few weeks ago, when the pump was running, the storage tank was empty, and the shut off float was lying at the bottom of the tank. it appears the installer zip tied the shut off float inside the tank, and the broke away. It was re-installed with stainless steel clamps (two of them) and all seems good now. I'm glad that you gave it "two thumbs up", I appreciate it!
Only question is he wants me to drain the storage tank soon, and my fat butt sure ain't crawling into the little inspection hole. How do I clean the sediment from the bottom of the tank? Should i use a little submergable pump after stirring up the gunk?
Old 05-09-2012, 03:29 AM   #6
We had a tank like that needed to be cleaned.
After draining the water we used a shop vac with a two inch pipe as a extension to reach the bottom. It work great.
If the sediment is like a sand, you may have to add a little water to help the vac pull up what ever in on the bottom.
Edit Signature
Old 05-09-2012, 03:48 AM   #7
Likes Given: 19
No, the sediment is a real fine silt. I like the shop vac idea. Thanks!
Old 05-09-2012, 02:29 PM   #8
Liked 24 Times on 24 Posts
Likes Given: 11
I have a question. Why the tank in the first place? Is his well a low yield well? He has a top of the line bladder tank.
speedbump is offline
Old 05-09-2012, 02:34 PM   #9
Administrator
Liked 167 Times on 147 Posts
Likes Given: 16
Maybe he will trade me for my bladder tank? As for the cleaning use a shop vac.
Should have called me on Monday I was in Arrowhead doing a job. I have a skinny guy that works for me, he fits inside tanks real well.
Chris is offline
Old 05-09-2012, 07:45 PM   #10
Likes Given: 19
I don't know for sure but I would assume the holding tank is for irrigation purposes, since he has 5 acres and a huge Koi pond, which is now used as a toilet for the damn bears up there.
Noises - looking for advice primer General Plumbing Help 8 03-25-2012 01:02 PM
I've tried just about everything - need advice from experts DINO128 General Plumbing Help 1 11-27-2011 09:34 PM
Advice - Had a plumber come out. arsenik General Plumbing Help 5 07-29-2011 02:36 PM
Need toilet advice RickVS Toilets and Sinks 6 06-01-2011 07:33 PM
Looking to get into this trade, need advice. jpalms General Plumbing Help 2 08-12-2010 01:58 PM
