Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > Sump Pump Float Switch
Old 10-10-2013, 04:02 PM   #1
steph
Liked 3 Times on 3 Posts
Default Sump Pump Float Switch
I just moved onto a place with a sump pump, which isn't working, of course. The first thing a did was make sure the outlet was good and I noticed a small stem sticking out of the float switch. Does anybody know what it is, I searched on-line but found nothing thanks.
steph is offline
Old 10-10-2013, 04:18 PM   #2
Liked 416 Times on 347 Posts
Likes Given: 61
Please post a picture for us, since a picture is worth a 1,000 words.
Old 10-10-2013, 06:07 PM   #3
steph
here ya go
steph is offline
Old 10-11-2013, 12:16 AM   #4
Liked 384 Times on 324 Posts
Likes Given: 549
I have never seen a plug like that. I don't think it is an overload or GFI protected plug, it doesn't appear big enough.
Old 10-11-2013, 01:01 AM   #5
Likes Given: 61
Nor have I. Hopefully someone will pop in soon to help all of us.
Old 10-11-2013, 01:16 AM   #6
Likes Given: 218
It looks like a piggyback plug. The first plug that's into the outlet is the float switch that's in the basin. When the float rises that first plug is a switch the puts power to the second plug which is connected to the pump. To see if the pump is working plug the second plug directly into the outlet. Here is a link to the switch. It's the second item on the page.
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3AFloat%20Switch%2 0Sump%20Pump
phishfood Likes This
Old 10-11-2013, 04:06 AM   #7
steph
I know its a piggyback plug, what I'm trying to figure out is what's that little white stem coming out of it.
steph is offline
Old 10-11-2013, 05:49 AM   #8
Likes Given: 218
The stem may be some type of vent that is needed when manufacturing the part. It has nothing to do with the operation of the switch.
Old 10-11-2013, 01:30 PM   #9
speedbump
Liked 47 Times on 46 Posts
Likes Given: 13
That vent tube must be able to breathe. It's something to do with the float. I'll be darned if I know what though.
speedbump is offline
Float lever sticking & power to jet pump problem Zanne Pumps and Wells 19 04-05-2013 04:04 PM
Pump not turning off even after float switch replacement forwardlookguy Septic Tanks 9 10-14-2012 02:29 AM
Pressure switch/well pump issue? ah55 Pumps and Wells 6 02-25-2012 11:03 PM
cistern pump and float switch question dx75 Pumps and Wells 1 10-07-2011 02:34 PM
Pump Control Switch? Kawiski Pumps and Wells 6 07-21-2010 04:07 PM
