Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > Sudden Drop in Pressure before Pump comes on
Old 02-28-2013, 01:30 PM   #1
fitch
Default Sudden Drop in Pressure before Pump comes on
Hello All,
I have just installed a new pressure tank and tank tee, and I am now having a (hopefully) minor issue.
When the pressure drops from water usage there is a small lag where it will suddenly drop 10-15psi below the cut-in pressure as the pump is kicking on.
I believe that it is just because I have my cut-in pressure too high (or equivalently my tank pressure is too low - needs a little additional air) but before I either adjusted to Pressure Switch slightly lower (more water volume between cycles = longer pumping cycles, at a slightly lower pressure) or adjusted my tank bladder slightly higher (slightly higher system pressure - slightly reduced water volume between cycles = shorter pumping cycles) I wanted to make sure that I was thinking this through correctly.
Please let me know that I am thinking this through correctly, and offer any helpful advice.
Cheers,
Fitch
fitch is offline
Old 03-01-2013, 03:24 AM   #2
waterwelldude
Water well,and septic guy
waterwelldude's Avatar
Liked 3 Times on 3 Posts
If your cut in pressure is.....say, 30psi The pressure in the bladder tank should be 27psi.
You can check this by turning off the pump, drain the pressure off the tank, then check the psi in the tank with a tire gauge.
Edit Signature
waterwelldude is offline
Old 03-01-2013, 12:42 PM   #3
Valveman
Pump Controls Tech
Valveman's Avatar
Liked 11 Times on 8 Posts
In other words you probably have too much air in the tank for that pressure switch setting.
www.cyclestopvalves.com
Valveman is offline
Old 03-01-2013, 04:56 PM   #4
fitch
Thanks Valveman that is what I wanted to know. Opposite of what I was thinking.
Cheers,
Fitch
fitch is offline
Drop in water pressure...is it this pump? gronendael General Plumbing Help 14 01-14-2013 08:43 PM
Drop in water pressure fishnof General Plumbing Help 13 05-22-2011 12:04 AM
Sudden very slow pressure tank filling HMonk Pumps and Wells 3 02-17-2011 12:41 PM
Sudden pressure drop before pump kicks in mikenh General Plumbing Help 4 01-04-2011 08:43 PM
Need to gain height at right-angle turn (go from 8" drop to 4" drop from 90* and T) aviator79 General Plumbing Help 3 11-09-2010 12:36 AM
