Plumbing Forum - Professional & DIY Plumbing Forum > Specific Plumbing Discussion > Pumps and Wells > Submersible pump
Old 05-01-2012, 12:58 PM   #1
Mec
Default Submersible pump
Hi,
I would like to know what's the difference between a submersible dry pit pump and a submersible wet pit pump?
Thanx
Mec is offline
Old 05-02-2012, 03:36 AM   #2
Water well,and septic guy
waterwelldude's Avatar
Liked 2 Times on 2 Posts
Thats easy, one pumps air and the other pumps water...lol..Just kidden
A wet pit is where the motor runs in the water, or the pump or wet end, is on top of the motor.
A dry pit pump is one that will pull water from its bottom. The motor is over the pump or wet end.
That is the way I understand it.
Edit Signature
waterwelldude is offline
Old 05-03-2012, 01:10 PM   #3
Mec
Hi,
I still don't understand the design because both models are submersible.
Mec is offline
Old 05-04-2012, 03:44 AM   #4
I believe a submersible dry pit pump serves to remove all the water from the well or pit. It has the ability the run dry for periods without harm to the unit.
A submersible wet pit pump is one in which the pump must stay submerged in water to maintain proper cooling and operation, and the refill rate of the well or pit will always exceed the pump's ability to pump out water.
doctordirtpro is offline
Old 05-04-2012, 02:53 PM   #5
Mec
Thank you!
Mec is offline
how to replace 110v lead to submersible pump?? kouvakis Septic Tanks 3 02-21-2012 01:41 PM
Submersible Check Valves Pikanjoe Pumps and Wells 3 12-03-2011 01:39 PM
Stolen Submersible Pumps jerrywilliam Pumps and Wells 8 04-07-2011 12:51 PM
