Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > Reverse Osmosis with jetpump. Rapid on and off
Old 11-26-2013, 03:57 PM   #1
JulianC
Default Reverse Osmosis with jetpump. Rapid on and off
Hi folks!
I have a jetpump in my place and I just installed a GE reverse osmosis water system. I wasn't able to find any leaks when I installed it but now I am having a problem. I will from time to time get a constant on and off state happening with my pump. By that I mean that within the space of about 5 seconds it will turn on, off, on, off, on, and so on. When I turn off the water to the osmosis system it doesn't happen so I'm pretty sure that the osmosis system is the problem.
Has anyone experienced this before? I just have to leave it shut off until I can figure out why this is happening. Many thanks for advice.
JulianC is offline
Old 11-27-2013, 12:19 AM   #2
Liked 391 Times on 328 Posts
Likes Given: 556
If you have a standard bladder tank on your well, the pump should not cut on and off that rapidly under any circumstance. That makes me think that your bladder tank is bad.
It is not unknown for a reverse osmosis system to malfunction and constantly backwash to the drain. This could cause the pump to cycle on and off, but like I mentioned, a bladder tank system should not cycle nearly as quickly as you are describing.
phishfood is online now
Old 11-27-2013, 01:39 PM   #3
speedbump
Liked 47 Times on 46 Posts
Likes Given: 13
Is this jet pump a booster pump or is it your well pump? If it's your well pump, like Phish said, your Bladder tank is probably bad. This condition can cause your motor to burn up way before it's time.
speedbump is offline
Old 11-29-2013, 10:04 PM   #4
Valveman
Pump Controls Tech
Valveman's Avatar
Liked 11 Times on 8 Posts
It might be that you just have a little too much air in the tank. If your pressure switch is turning the pump on/off at 40/60, make sure you don't have more than about 35 PSI air in the tank when it is empty of water.
www.cyclestopvalves.com
Valveman is offline
Reverse Osmosis larbec General Plumbing Help 3 11-25-2012 04:25 PM
Reverse osmosis problem solving advice chaseme5 General Plumbing Help 2 03-17-2012 04:38 PM
Reverse osmosis water waste markdecker Pumps and Wells 5 07-28-2011 02:15 PM
Reverse Osmosis Question therohz General Plumbing Help 6 12-28-2010 02:21 AM
No space for saddle valve for reverse osmosis system. mn3 General Plumbing Help 3 06-22-2010 11:01 PM
