if there is no check valve at the tank then a leak in the drop pipe, or the pitless adapter or anywhere from the check valve on the pum to the tank, would make the pump cycle on and off when no faucets are open. If there is a check valve at the tank then it could be a leak in any of the a fore mentioned pipes.
When in doubt, hire a licensed professional
